Kissing cousins ???????
5,709
So my buddy rolls up the other day and asks me to check out a leak he is having on one of his cars.
So I throw it on the hoist, and sure enough there is trans fluid leaking.
But its leaking from under the "coolant overflow bottle" area.
I immediately pop the radiator cap(engine was still cool, he live close by 😉 )
Just as I suspected, the transmission and radiator are "swapping spit"
Well I know whats next....."Hey man, can you fix it?"
Well let me tell you brother, that damn radiator was "poured in" at the factory....Holy sh1t!!!!!
I hate dealing with cooling systems anyhow, but to top it all off the damn engineers didn't put a petcock on the damn thing:mad:
And I have to basically rip the front end off to get to it.
Damn coolant just floods the floor when I pull the hoses.....
and without this little tool.....I have no idea how you would get those hoses off and on.
totally "worth it's weight in gold"
It sneaks into places no pliers could dream of getting to.
I have no idea where I got it, and can't read the name of it anymore, but I'm sure glad I have it
Aside: My wife always "bangs on me" about keeping "useless sh1t"......and I have this area in my box, where I keep "specialty items"
It has save my a$$ more times than I can count though.
Here is my latest "find"........"Damn It" clips 🍻🍻🍻
In the box you go...........(evil laugh......:devilish::devilish::devilish:)
Then I start it, and the damn alternator light pops on.........I call him and he says "Oh yea, that popped on when I was bringing it to your place the other day....I figured it was related to the leak"🤦‍♂️🤦‍♂️🤦‍♂️🤦‍♂️
DaveFromMi
L3901 RCR1260
Apr 14, 2021
693
764
Indiana
I worked at an auto company where ATF in tank (rad) coolers expanded at a different rate than the radiator and caused ATF to get into the rad and coolant to the transmission. It was referred to as the pink milkshake of death since it destroyed transmissions.
bbxlr8
Mar 29, 2021
457
314
Eastern PA
Unfortunately, been there - got the t-shirt on this one & more common than you hear of.
Was w/my GMC during a trip & ANY water in the trans will delaminate the friction surfaces/clutch linings turning it into a brick either right away or greatly diminishing the lifespan . I should have bought a lottery ticket afterward but the only thing that saved mine was that I drove straight though and the higher pressure in the trans forced it into the coolant vs vice versa when you have repeat cycles. I pulled the pan, cleaned the e control solenoids deep inside while I was in there. New rad and complete flush of both systems incl. the torque converter. One not obvious step is using HD non-sudsing dishwasher cleaner for extra step to remove the film throughout the cooling system (also turn on the heater).
& yes, that tool is worth it's weight in gold - got an assortment of other clamp tools w/ mine at HF
EDIT - in hindsight, it is a lot of work, $$$ and hard to justify upfront, but replacing the rad w auto trans cooler seemed like a good plan on a 20+ year old expensive vehicle I bought new and don't want to ever replace.
