just purchased a GR 2000
twheels
GR 2000
Jun 3, 2010
Pa.
Hi, I just purchased a GR 2000 today, when I turn it to the hard left it turns nice, when I turn it hard to the right the right rear trys to lock up, I have adjusted the cable all the way both ways and even unhooked it and I still have wheel drag,it tears up the grass, it has a wet brake system,I can repair almost anything but this animal is a new 1 to me , PLEASE HELP!!!!!!! Thanks TW
eserv
BX24, A1000 Kubota Generator
May 27, 2009
2,189
169
Hardisty, Alberta
The GR2000 doesn't have a rear differential. It has clutches in the rear axle that disengage drive to the inside rear wheel in a turn, controlled by cables that go to the front axle to sense steering angle. I theory it should reduce tire skidding in a turn while still maintaining at least three wheel drive. In practice? well, they don't make it anymore and I wouldn't buy one!
Ed
twheels
GR 2000
Jun 3, 2010
Pa.
Thanks Ed for the quick answer, and I new it was to good to be true that I finally found a very good condition kubota, you could stick it on a showroom floor that's how clean it is.But I own it now:(
eserv
May 27, 2009
2,189
169
Hardisty, Alberta
Oh it's not a bad tractor! It just wasn't one of the best ideas! The rear axles did give a fair amount of grief, but if well looked after and not used rough thay can give good service. And they DO turn real sharp!
Ed
