Just checked air pressure..
09Ram
09 Ram 2500, Grand L3830, GST, 6 ft Brushhog, 6 ft Box Blade, 8 ft Disk, Auger
Jun 8, 2013
45
Tahlequah, Ok
I bought my Kubota L3830 back in May and always thought it rode pretty rough. It has R4's on it and has an FEL. I finally decided to check air pressure and both fronts had 50 psi and the rears had 17 psi. I checked my manual and it showed it should have 20 psi front and rear. I dropped front pressure to 25 psi due to the fact I use the FEL allot and I lift heavy. I upped the rear to 20 psi... tractor rides much, much better! I wonder why the dealership had 50 psi in the fronts?
4,004
My guess would be kids working in the shop that really don't under stand about tire pressure
Drew584
Kubota L3800DT W/FEL, and 60'' LP Brushhog
Jun 17, 2013
38
Mannford ok
Theres no telling why it had that much air in them. Probably had the air hose in one hand and an Iphone in the other. If you want it done right you have to do it yourself!
ipz2222
L235, bx2670
May 30, 2009
1,927
chickamauga ga usa
I bought a rider mower from Wall Mart once. The guy who worked there told me to be sure and ck the tire pressure when I got it home. He said they were shipped with high pressure just in case they had a small leak, they would stay up longer.
