S Sdatrucking Member Equipment B7100. Aug 26, 2022 58 20 8 Tagalong3746 Dec 24, 2023 #1 Did Jacobsen golf course mowers run Kubota motors found someone with 3 of em cheap haven’t seen em yet but sellin cheap and guaranteed to run
S Sdatrucking Member Equipment B7100. Aug 26, 2022 58 20 8 Tagalong3746 Dec 24, 2023 #2 Little research these would be 37.5 to 50.2 hp def not fitting my 7100 will try to get eng model they are Kubotas
MOOTS Well-known member Lifetime Member Equipment MX6000 Jun 27, 2019 2,189 2,718 113 Canton, Georgia Dec 24, 2023 #3 Sdatrucking said: Did Jacobsen golf course mowers run Kubota motors found someone with 3 of em cheap haven’t seen em yet but sellin cheap and guaranteed to run Click to expand... Yes, possibly. Lots of turf equipment from all the brands used kubota engines. Reactions: 1 user
P PaulL Well-known member Equipment B2601 Jul 17, 2017 2,662 1,644 113 NZ Dec 25, 2023 #4 Sdatrucking said: Little research these would be 37.5 to 50.2 hp def not fitting my 7100 will try to get eng model they are Kubotas Click to expand... "Fitting". Well, 50hp would "fit" just fine. But there might be quite a bit of fabbing to make it fit.
W Wull Member Equipment Tractor Mar 21, 2023 74 14 8 Scotland Dec 27, 2023 #5 Yes, we currently have 3 Jacobsens fitted with Kubota engines, we also have a few other manufacturers using Kubota engines.
V Vigo Well-known member Equipment B6100, B8200 Jan 9, 2022 595 341 63 San Antonio Texas Dec 27, 2023 #6 As much as i love a power increase a 7100 doesnt have enough weight to use much more power than it has. Unless you want to pull a massive pull-type mower deck maybe.
