Hard to tell exactly but that appears to be installed in place of the standard outlet block.
Whats bothering me at this point is the cartrudge style sequence valve. If it were a flow divider I would understand the operation but I can't understand what a sequence valve accomplishes. Maybe reading the manual cover to cover will give me some insight.
In any event the plumbing seems clear.:
- The IN and AUX ports on the steering valve go to the two male JIC fittings on the top of the outlet block
- The low pressure OUT port on the steering valve gets teed into the factory relief valve hose on the pump.
- The front port on the side of the block goes to loader IN port and loader PB port goes to the rearmost one.
- The diverter valve handle must be placed in the outward pointing direction. If not the loader wont work.
Hook it up that way and tell me what does or does not work.
Da
