Why no love for the hydraulics
? Their concept is really simple.... You need to take some pictures of what your working with so people can better assist you
I read on another one of your posts that you have a FEL. How is the hydraulics fed for the FEL? Does it have it's own pump on the front of the tractor? Is it fed from a hydraulic block next to the break pedal? There is a few different ways to tap into the hydraulics and add onto.....
In my opinion, quick connects are only worth it if you need to disconnect lines frequently. It only takes a few minutes to spin a few fitting, and quick connects will leak before anything else. Once they do, replacing is about the only option and they aren't cheap! If it was a NPT or JIC fitting, it just may need tightening or little pipe dope to seal the deal. SAE, a new o ring fixes that.
What do you plan on running with extra remotes?
