I just purchased a used 2011 RTV900XT. The front drive shaft is bad with much slop. How do I remove the drive shaft
Robert Seigworth
L3901, RTV900XT
Jul 26, 2021
21
Florida
I just purchased a used 2011 RTV900XT. The front drive shaft is bad with much slop. How do I remove the drive shaft with regard to disassembly. Are there aftermarket drive shafts available. Kubota wants $650 for a new one piece drive shaft. Thanks.
eserv
BX24, A1000 Kubota Generator
May 27, 2009
2,189
169
Hardisty, Alberta
Remove the tin "skidplate" and remove the centre hanger bearing then the shaft will come out. The kit from Kubota is the best way to fix it.
Robert Seigworth
L3901, RTV900XT
Jul 26, 2021
21
Florida
Thanks for the reply. My 2011 RTV900 has the one piece drive shaft. There is no hanger bearing on this unit. I was wondering how to disconnect the cv-joints from the transmission and the front differential end. I am new to CV-joints other than front wheel drive cars. There must be be a circlip or something I need to remove to start the removal process. Any suggestions would be appreciated. Thanks.
eserv
May 27, 2009
2,189
169
Hardisty, Alberta
Simply pull them back and they will come off. Start with the front one. The "skidplate" must be off. If there is a lot of slop in the front joint you may have to replace the front diff ring and pinion to correct it!
Robert Seigworth
L3901, RTV900XT
Jul 26, 2021
21
Florida
Thanks so much! I did exactly as you suggested and now have the front drive shaft off and out from underneath the UTV. Do you know if a good machine shop could make or repair the old drive shaft? Good machine shops are hard to find in Central Florida anymore. Thanks.
eserv
May 27, 2009
2,189
169
Hardisty, Alberta
I would repair it myself if I owned it, so, yes, I think a good or average machine shop could do it. It likely wouldn't be much cheaper than a new one from Kubota though! I would try installing it end for end, put lots of grease in there and you might get a lot more running out of it. The front seems to get sloppy first and end for end might help a lot
