I am new to this forum and would first like to say hello to everyone. Secondly I am having a hydraulic problem that has me confused. I have a L3410 HST with a loader. when I use the loader to lift the front end of the tractor or lift a heavy load hydraulic fluid leaks from the front of the pump where it bolts to the housing. I pulled the pump, checked for play in the shaft (was none) and replaced the seal. Thought my problems would be solved but I was wrong. fluid still leaks between housing and pump. My question is could there be something else maybe causing the pressure to be to high for the pump seal to handle.
