Working the L3600GST this weekend started hearing a squeak/Chirp shifting from F to R and noticed a delay. Checked sight glass and looked way low no bubble and thought it was below sight glass. Had a wet hose connection for a wile so after fixing what I thought was leaking I got a new pail of UDT w/ a filter figuring I could spin it off and swap it out fast. Lost only about a qt I think. Then poured in a lil fluid and checked, looked the same. Kept pouring and checking, looked the same. Got nervous read some posts and decided to try to use a clean piece of wire for a dip stick and looked like it was some place near the window but its hard to judge for sure. Took a pic of the window to see if any one would care to offer up an opinion if I am full or still down a quart or two. I used up the 5 gallons and now wondering if IM way over? I checked with the machine warm, cold, off, running, all rams relaxed, contracted once with a bologna sandwich in my left hand. Still looks the same to me. Sorry if this is a lame question but if any one has insight it would be greatly appreciated. Incidentally the squeak did fade after a few shifts and seems to be working ok but just want the right level.
Thanks
Sean
Thanks
Sean
