Hydraulic fluid Is Red
Rcflyer330
Kubota B2650 Cab, B2779 Broom, B2782B Snowblower, RB1672 rear blade
Oct 14, 2019
110
61
Traverse City, Michigan
Thats not much information to go on. There are many manufactures that color their fluid. Most likely you will never find out which brand it is do to the many that are out there. The dye can also be to any brand of fluid. What are you trying to do add some or replace the fluid?
wdlanning
L3750, L4310, B20, Genie Boom
Nov 7, 2016
221
11
philadelphia pa
Wanted to add to l4200
dvcochran
Kubota M9000, New Holland TN90, Deere 2640, Vermeer 504N, Vermeer 504SI, more
Feb 23, 2011
214
45
Dickson, TN
What manufacturer produces red/rose colored hydraulic fluid?
The older or straight hydraulic systems like the ones frequently seen in industrial applications to supply power often use the old 303 fluid which is usually red. I doubt this is what you want to use.
jnschnit
B2601, BH70 BH, LA435 FL, RCK60-32 MMM, BX2763 Blade, ZD1011
May 10, 2013
136
45
newark valley new york
MIL-5606 was what we used on B-52, that was red. Maybe someone got a deal on some surplus?
3,322
Mil-5606-Hyd fluid is red. Not often found in tractors I don’t think, tho’. I”ve seen it used in 2,000 psi aircraft hyd systems for flight controls, brakes, landing gear actuators, flaps, ets. It’s a simple mineral-oil base universal type fluid.
3,322
Bark
L4701/FM2560LA765/BB2560Pittsburgh disk Titan P forks
Feb 18, 2020
202
54
North CA
Its possible somebody put some Oil-Glo 50 "easily pinpoints leaks in hydraulic fluid" (their ad) or a similar product in the system. If that's what it is, it shouldn't hurt anything but you may want to change the fluid just in case.
Tx Jim
M7040 HDC & JD 4255
Apr 30, 2013
1,219
141
Coyote Flats,Texas
Ditto what Bark stated. Hyd oil possibly could of had dye added. I added red dye to my JD 4255 & Kubota M7040 hyd reservoirs so hyd oil level on dipstick could be more easily seen.
Bark
Feb 18, 2020
202
54
North CA
Not wanting to hijack the thread but that is brilliant guys. I have only used it when trying to find a leak in something. With my eyes, I have a heck of a time seeing the UDT2 on the dipstick or anywhere else.
Popgadget
L6060
Mar 11, 2020
42
17
PA
Could also be Dexron ATF. It’s often used as a hydraulic fluid, but shouldn’t be used in a common sump tractor because it lacks the extreme pressure additive for the differential..
Any leaked 5606 gets pretty gooey in a short time.
