hydraulic fluid change b20
ggmeadefox
snohomish wa.
my b20 has milky hydraulic fluid I think its time to change it. I bought the kubota fluid 7.5 gal. went to napa for the filters now does anyone have any tips?
bruceatlam
B20, FEL, box blade, flail mower
Aug 20, 2009
410
Camarillo, California
I doubt that the NAPA filter meets the spec for the HST filter --- check the micron rating of the filter against the spec. I bought the Kubota filter for that reason.
Drain teh main tank first and replace that filter. There are then two drains under the transmission in the very back --- remove those and drain what you can. I think that I got about six gallons out total. Replace the HST filter.
I filled the main tank through the fitting on top of the tank. Once that was full, I started adding fluid through the fill port on the transmission. I used an old Tide bottle to pour from ---- it's got a nice built in funnel. Wash it out well of course. Top off the fluid level once you have it running. It's not a bad job.
