Hydraulic Fittings Steel VS Brass
Mork
2014 BX25D
Apr 20, 2015
37
Mt Pearl, NL
Is there any safety issue in using a brass coupler on the end of a pressure test gauge vs a steel coupler? Our local hardware store stocks the correct size but in brass only.
thanks.
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,257
1,043
Williamstown Ontario Canada
Sounds like you are using a fitting designed for compressed air systems which are typically running around 110# although two stage ones used in truck repair go to 175#.
Hydraulic systems are running in the range of 2,500 to 3,000#.
Get to a specialty hydraulic shop to get a steel fitting designed for the pressure of a hydraulic system.
Dave M7040
