For Sale: 2 loader lift cylinders, 2 loader bucket cylinders & valve assemble from a LA1065A loader. Could be used for other uses. Lift I believe are 7J275-63050, pin holes are 1 3/16” diameter, center on center-extended length 50 ¼” retracted 30 5/8” rod dia is 1 3/8” tube OD is 2 ¾” guessing 2 ½” piston. 2 bucket I believe are 7J275-64050, pin holes are 1 3/16” dia, center on center-extended 45 ¾” retracted 27 ¼” rod dia 1 3/8” tube OD is 2 17/64” guessing 2” piston. Valve assemble I believe is YS027-00100, oil feed block 7J266-68113, hoses & couplers. 6 cylinder pins. Cylinders are $100 each, valve, single lever control, block, hoses & coupler $225. All as is, cash only. Any questions, PM me and I will get back to you. I am in WIS.
