hyd pump intake screen
LRP
202
canada
thanks to service dept Vic, i drained the trany oil tonight and pulled the screen out. it was half pluged. this was new oil that i used when i replaced
the reverse gear. mabe 15 min run time, anyhoooo,
before i installed the trany oil plug when doing the reverse gear, i machined
a cavity in the plug and installed a powerful rare earth magnet. here is a pic
when i took it out tonight. i had spent an hr draging a magnet on the bottom of that trany and i took out lots of fine metal.
this is what it looks like after i wiped it clean.
Orange Tractors
Jul 19, 2009
323
Butler, MO
If I have a choice, I prefer to have a magnetized drain plug in everything. It just makes sense to collect all the little steel shavings; instead of letting them float with the oil, potentially causing problems.
Robert
JimBeard
Tiller ,6Foot Blade,FEL,3pointFinish Mower
Mar 1, 2010
40
Manchester NY
Good idea on magnet i attach a couple of magnets near the drain plug then remove when i change oil .
