Hst pedal don't return to neutral
Yallaire
L4600 hst
May 30, 2022
North western, Québec
Hi, my first post here,
I have a L4600 tractor, that the HST pedal don't return to neutral, i need to press on the reverse to stop the tractor.
It's a 2013 tractor with 900 hours.
I thought it could be the damper, i removed it and the problem is still there.
There are a lot of moving parts, and i can't see any greasing zurt.
Any input will be appreciated
Thanks
rbargeron
Jul 6, 2015
1,183
260
western ma
My experience is with the earlier HST version, but problems can be in the external control linkage - your hunch about the damper was in the right area. Its possible the servo regulator or servo piston has gotten out of adjustment - the zero point between forward and back is very sensitive. On mine the actuating rod had gotten slightly bent, so the machine would "creep" at mid-pedal. You could try experimenting with adjusting rod length as a starting point. Dick B.
Yallaire
L4600 hst
May 30, 2022
I should add, not only it doesn't return to neutral, it sticks either to forward or reverse, once i press on the pedal it stays there.
The tech at Kubota just told me it could be the rod going throu the transmission or a bearing.
I'm trying to fix it myself... simply because of the cost of mob demob...
Thanks
3,345
Thanks
I would spray penetrating oil on all the linkage/pivot points first. Maybe several times over several days. Then if things loosed up I would lubricate with heavier oil.
Can't hurt to try. IF the issue is internal doing this will not affect it anyway...you will not make it worse.
crbr
2006 B7800, 2022 BX1880
Jan 8, 2010
34
25
TN
I realize you stated you do not see a zerk. Look closely. Mine was hidden by other components. Some of the older (2006) tractors have a grease zerk at the pivot point. Not returning to neutral (safety switch) was an inherent issue, thus the no-start symptom.
Shot of grease if your new model has the zerk.
rbargeron
Jul 6, 2015
1,183
260
western ma
Thanks
Staying in either position is different than not fully centering when released. I agree with lubing everything you can get to.
lmichael
Kubota G2160
Apr 23, 2021
800
412
Rockford IL area
I have this same issue with my G2160. Would love to know how to correct it. Seems to return just fine when not running. But when running it's a little stiff for lack of a better description. It's pretty funky linkage on it. I may try some spray lithium grease on the linkage.
Thatoneguy
Kubota b7200
May 20, 2022
67
12
Southern California
I have a similar problem with my b7200. After spraying some lube on the contact points, it definitely helped the issue but has started to returned with use as the dust builds back up. I did notice a tensioner type spring in mine which adjustment is maxed out. Perhaps the spring is worn. I have seen miscellaneous springs at my local hardware store that might help by putting a heavier spring in it to assist the pedal returning to neutral. Assuming you have a spring like i do
woodman55
L6060HSTC, RTV 1100
May 15, 2022
1,050
869
canada
Your linkage looks very similar to my old L5030, I looked it up on "Kubota parts finder Canada". Mine was not nearly as bad as you're, in that it returned to neutral but would shut off the engine when I got out of the seat. The bearing that rolls against the arm that the dampener is connected to was bad. My damper was also weak and sticky. Plus the linkage was a little out of adjustment. There is a rod with two ball joints in it that connects the hst pedal to the arm that the damper is connected to, disconnect the rod, then you can isolate the problem to one side or the other. My recommendation is to purchase the service manual, you can purchase a pdf version and download it, it is well worth the money. Then "IF" you feel comfortable doing this, disassemble that linkage and clean/lube/repair as needed. Then adjust the linkage back to spec. Hope this helps.
lmichael
Kubota G2160
Apr 23, 2021
800
412
Rockford IL area
Well I jacked up the machine the other day, dropped the deck and was able to spray some penetrating grease into a couple more places. Freed up quite a bit. I need to do it again but with a helper working the linkage via pedal while I am under it doing the spray.
Yallaire
L4600 hst
May 30, 2022
Finally i simply removed 2 bushings lightly sanded and put it back together. With grease.. nearly cost = 0$
lmichael
Kubota G2160
Apr 23, 2021
800
412
Rockford IL area
Still sticky. Worse when running than when not. Not sure why. Still going to try once I get a helper to work the pedal while I spray in lube
