How to measure fluid level
countrygunner
Kubota B2650
May 31, 2023
Viper, Kentucky
got a l4300dt with the fluid level window. Well it’s fogged or discolored and I can’t see fluid anymore. How to fix this or at least check the hydronic level
old and tired
L2800 HST; 2005; R4
You can add red dye to the hydraulic system or you can replace the sight glass.
For replacement, get on a side slope angle where the oil goes to the other side.
John Deere makes a red dye, https://shop.deere.com/us/product/MT3668:-Hydraulic-Oil-Dye-Fluid,-D-50,-12-ml/p/MT3668
Only need 1/2 or even 1/4 bottle, it's only 12ml but 1/2 a bottle turns mine really red...
Is the fluid gauge on the back of the tractor? (vs. the side of the transmission?)
g_man
Feb 3, 2023
301
1,350
NE Vermont
Are you sure that your fluid isn't low and below the window or high and above it ? If you haven't already done it find a steep hill And check it with the front low and/or with the front high. It's very hard to tell what your looking at if the oil level isn't in the window.
gg
JonM
L6060,SA20,4in1,BH92,QH16,BS40,APS1572,RTR2570,HR2572,WC1504,FM2584,SBP1684
Nov 29, 2024
117
237
wisconsin
dont stresd too much my l6060 has a dipstick for hydraulic level and its every bit as difficult to get an accurate read. lol
4,173
For 20 bucks, just get the "JD red dye" and be done with it.
I would add that, I agree with @old and tired that you only need a small amount.
(However, the thought of having ANOTHER “partial" bottle of “such and such” taking up more space, contributing to the already insane clutter on my shelves….I just poured the whole damn thing in, so I could “in good conscious” throw it way……:) YMMV)
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
2,817
2,225
Near Lancaster, PA, USA
It helped me see the fluid after I sanded the metal dipstick to create a "grain".
WI_Hedgehog
Apr 24, 2024
878
1,219
Milwaukee, Wisconsin, U.S.A.
I lay the dipstick flat against a clean, dry paper towel, then turn it on edge. The paper towel absorbs the oil and witnesses the level, which is now easy to read.
