how to disconnect the drive shaft from a kubota bx 2380
sharon
kubota bx2380 with brush hog,scoop,bellie mower and road grading
Jul 16, 2017
livingston
I have a new tractor which we have not been able to remove the brush hog from the tractor as the drive shaft keep pulling apart in the middle :eek:
Wbk
307
St Adolphe Manitoba Canada
Re: how to disconnect the drive shaft from a kabota bx 2380
You have to pull the lock collar back first at the pto shaft where it exits the tractor then pull the driveshaft back.
ppop
bx23D
Nov 15, 2016
paupack, pa
How do you pull back the plastic hood on the leading end of the shaft in order to access the collar?
Cglaza
L2500DT, BX2380, G6200H
Aug 30, 2015
176
Freeland, mi
You might have to shove it forward first, then pull back on the collar and pull the shaft off
Sent from my XT1710-02 using Tapatalk
BensBX
59
Baltimore, Ohio
The BX Kubota is really tight area to access easily and can be very frustrating when either connecting or disconnecting the drive shaft on the pto. There are a couple different collar release methods and would suggest you google pto driveshaft or youtube to find what matches your shaft. I had to cut of a large portion of the protective plastic shield (bell portion) because there was no way to get your hand inside it to push the release pin and slide the driveshaft off. Be aware and look closely at the amount you can cut down without messing up the integrity of the safety sleeve.....otherwise don't alter it. Finally, if it went on it will also come off but may require a language challenge. Surely someday a pto engineer will design a far, far easier method of connection especially on compact tractors.
Cglaza
Aug 30, 2015
176
Freeland, mi
You should be able to lift the PTO guard up to get better access also
2,307
You can usually disconnect the shield and pull it out of the way (make the plastic shaft cover shorter)
ppop
bx23D
Nov 15, 2016
paupack, pa
Thanks. Depressing plastic visible in four holes in vaned cone shield ring unsnaps plastic and allows leading edge of plastic bell to be peeled back thereby exposing PTO collar slide pin.
Johnacman
Kubota L2501 & B7100
Jul 26, 2019
Independance, La. US
You do know there is a locking pin on the female end of the shaft that must be FULLY depressed to get it off. Also the splines need to be greased often so the
shaft slides easily.
