How much counter weight ?
Toby 1
Box 2670
Aug 11, 2013
Kaukauna Wi
I have a BX 2670 with fel bucket and quick detach forks . How much weight do I need to keep the back end on the ground?
2,857
Welcome Toby,,
A few questions first,,
Are your rear tires filled?
Do you have wheel weights on the rear wheels?
Have you thought about buying or building a weight box, there are a few threads on here about them.
Remember you have a LITTLE tractor, shes a beast but still a little tractor. Your not going to be lifting a ton with the FEL, I would suggest fill the rear tires, and that will give you another maybe 60 pounds weights at the axel, and invest in a set of wheel weight 75 pounds for each wheel (150 pounds total), and with you on board you would have about 400 pounds total, which should be enough to off set anything your going to be lifting.
Bluegill
Jan 11, 2012
1,560
Success Missouri
Wheel weights and loaded tires are great for stability, but I want 'counter' weight on the 3 pt hitch for any loader work! Not very familiar with BX models, but I'd guess 300-500 lbs would be good.
bcp
BX2360
Apr 20, 2011
645
77
SW WA
From BX2360 manuals:
Loader manual recommends a maximum of 420 pounds on the rear as loader ballast, if no implement attached.
Tractor manual recommends a maximum of 275 pounds on the front as rear implement ballast, if no loader installed.
Bruce
In Utopia
L175 FEL
Apr 21, 2013
589
Utopia,Tx/Pasadena,TX
I made this for my L175 with a FEL.
Weighs almost 500lbs. I used 6 70lb. concrete blocks for weights and can remove or add if needed. Also left room on top for tools and a chain.
Also water filled the tires.
Bluegill
Jan 11, 2012
1,560
Success Missouri
Bruce
That would be on the 3 pt and not on, or in the rear tires. Just stating that because not everybody knows... Makes a difference and it is in the manual for reason.
bandaidmd
B2620 w/LA364 FEL ,BH65, ssqa , 1982 B8200E w/BF300FEL
May 19, 2013
603
Middle of DELMARVA
Since it doesn't fall over forward with nothing on the front the quick answer would be the counterweight should be at least as heavy as the item your picking up.
BCP's reply of 420 should cover all senarios
kubotaman574
BX2670 B2650
Aug 8, 2013
106
Elkhart In
Welcome Toby,,
I just filled my New BX2670 Rears, Added 112 per tire, 14 gal.
