I've just replaced the second 4WD/Bi Speed hydraulic valve because the 4WD solenoid burned up again. It is identical to the Bi Speed solenoid, and they are stacked on the same valve. The whole valve is expensive and they wont't just sell the solenoid. The Bi Speed operates cutting in and out as you steer, but the 4WD is on continuously. I installed the new one and it gets hot right away.
Kubota Corporate or the local dealer has no answer.
