I have a M9540 2 wheel drive that after a day of bailing the 3 point will not lift. Some times if I move the outer remote it will then lift.
Thanks
Thanks
All of that is good. Changed hydraulic filters and fluid. Still having the problem. It is a little sticky even cold.Start by checking your fluid level. In the process check your engine oil as well. Sometimes you can get a hydraulic leak which pours fluid into the crankcase.
If a remote is not in the perfect neutral position it will bleed off the hydraulic pressure at the rear of the tractor.I have a M9540 2 wheel drive that after a day of bailing the 3 point will not lift. Some times if I move the outer remote it will then lift.
Thanks
No nothing connected to the remotes. I'm going to rebuild the control valve. Hopefully that will do it.If a remote is not in the perfect neutral position it will bleed off the hydraulic pressure at the rear of the tractor.
In simple terms, the Open Center hydraulics can only do one thing at a time, so something is dumping the pump volume.
Are you having things connected to a remote?
Dave
It seems premature in the diagnostic process.No nothing connected to the remotes. I'm going to rebuild the control valve. Hopefully that will do it.
Hoping the valve is sticking. Finally had a mechanic message me said he would start there. We will see.It seems premature in the diagnostic process.
The fact that moving a remote's lever suddenly makes the 3 pt work must mean something.
Dave
