Help with snowblower
alumley
G6200hst
Jun 2, 2010
12
Lyme Ctr.
I have a G2546A that I believe has a bad worm gear and I already know that the parts (maybe the 70060-01293) are probably going to be very hard to find but first I need to get the gearbox assembly off and I'm having a tough time getting this collar off. I don't have a puller small enough to get behind it, tried a little heat and rust solvent but won't budge. This all may be a waste of time if I can't find the part but worth a try I guess.
BX23-S,57 A-C D-14,
6,349
That 'may' be a locking collar. Have to hold shaft and turn is 1/4 turn one way( I forget which). There's a hole 'dimple' you put a drift in and then whack with hammer 2-3 times. If it doesn't totate , go the other way. Also file off the shaft on front of it, especially around the keyway, to help slide the collar off.they are a precise fit. When it is free, whack end of shaft with brass hammer and 'auger unit' should come out.
Caden
1979 B7100
Apr 16, 2026
440
256
Yes that looks like a lock collar, that unused hole in it is where you put a punch to rotate it. Sometimes you can look carefully and see the indentions from the last time it was "locked", and then knock it loose in the opposite direction.
