help please
I have just got a B6000E tractor it has no stickers left to tell me which lever does what. I also need to know what steps to take if I cannot get the transmission into neutral? I have tried all the positions on the shifters and found that if I put the transmittion in reverse the front wheels try to go forward while the back ones try to go in reverse???
Broken???
cmorningstar01
B7500HST LA302 FEL 5'Finish Mower B5100E 46" Snow Plow 22 ton splitter
Mar 27, 2011
341
81
Pemberton NJ USA
Sounds like someone may have switched the front differential with one from a machine that the engine rotates in a different direction or something is really messed up inside the transmission.
Kytim
Aug 14, 2009
848
15
Western Ky
Yes it is, an "E" model is a 2wd. a DT again is the 4x4.
well after a little exploratory surgury I found the reverse gear runs on the 4x4 shaft in the transmition. Which was siezed. I found that the 2 shifters on the left side of the trans housing are for pto control the front on I think is for different speeds the back is to switch from ground drive on the pto to motor drive. the right side 2 are high and low range and 2 - 4 wheel drive. Lots of levers for a machind no bigger that a quad. As for pictures I will try.
he he go to me come from u
Bill
