Thank you for the info, I'll check it out asap.Yes they work off the main key switch to the left of the steering column. Go to Kubotabooks.com and download the WSM for the schematic and service info
This is great, Thank you.The wiring may be odd because there is one wire for low beam and one wire for high beam and a single ground wire that attaches to the steel hood or enclosure. Here is the schematic of the wiring for a L185 and L245 which may be different from the L225 you have.
And honestly these headlights are really dim and nearly not worth worrying about.
