Maybe try comparing at the same measuring points.
When the L4760 has the 1055 loader on it, the max lift at the pins is 2361 lbs.
At 500MM in front of the pins it is then 1784 lbs
The MX with the 1065 loader is 2275 lbs at the pins.
At 500MM in front of the pins, it is then 1691 lbs.
These specs are from Tractor Data, if they are wrong, I apologize.
Normally it is best to compare using the same measuring points if you want an actual apples to apples comparison.
And you mention that the 3pt capabilities are not as important, to who, you? Many people use the 3pt much more than a loader. This is a perfect example of everyone's circumstances may not be the same and what works well for one person may not be so good for another.
