GR2120 FUEL BLOCKAGE
RICK jUDD
Ride on Mower GR2120
Aug 31, 2018
9
Bersac Sur Rivalier France
GR2120 RIDE ON MOWER. It has only done about 160 hours but the fuel keeps getting block in the fuel tank. Ihave back flushed it with compressed air and it flows freely. What is causing this to happen and how do I prevent it happening again. The next question is how do I remove the fuel tank?
2,052
Metal tank could have rust or plastic tank can grow algae. Either can get some junk floating around that will cover the fuel tank outlet.
You may try to vacuum diesel fuel out to try to get the junk out but never do that with gasoline. Which fuel type are you using?
