if this is the 'rider' (21hp ?) then.... according to the parts finder.','engine' section, ....DYNAMO, 150W/14.5 A
So... 14.5 amps total current out of the dynamo. Subtract say 5 for running with headlights on ?, you're left with about 10.. sub 8 for your heater( very small) and cab lights, now left with only 2 amps to recharge the battery..
It 'could' work though I don't like the 150Watts @ 14.5 amps, 13.2V x 14.5A = 192 Watts not 150.....hmmmm
Curious to know what the fuse rating is from the dynamo. I'm thinking 15 amps ? maybe 20 ??
What heater did you use ? Say it's 7 amps, 7*12 = 84 watts ,kinda like an 'old skool' 60 watt light bulb for heat..
So more detail and the full story…
heater = 2.9 amps
beacon = 19 watts / 12 = 1.58 amps
led cab lights = 2 x 18 watts / 12 = 3 amps
and the story
last weekend i was mowing the lawn and I went to turn off the engine and it kept running. Then I noticed that when I push the pto reverse button the light didn’t flash And I was able to go in reverse with the pto engaged.
Killed engine - restarted engine and engaged the pto and was able to go in reverse without the reverse pto button pushed.
It gets better…next, while standing next to the mower I was able to start it and engage the pto. No pushing the brake or sitting on the seat.
Took to my local Kubota dealer and so far the can’t figure out what is wrong, but are thinking my accessories draw too many amps and fired something.
First kinda scary that if the safety features fail open ie, they just do not work. Second, I can’t see ~8 amps off the battery firing something.
