Glide shift transmission
eserv
BX24, A1000 Kubota Generator
May 27, 2009
2,187
170
Hardisty, Alberta
Hi mrsmith
The GST transmission is basically just a standard transmission, fully synchronized, with an automatic, hydraulically activated clutch when you move the shifter to change gears the clutch is released and then reapplied somewhat like the old VW automatic.
They have been very reliable and are considerably more efficient than the hydrostatic transmission.
Ed
Ob1kubota
M9540DT
Jul 26, 2009
316
Birmingham, AL
I second that, my maintenance on an HST ( Fluid and filter changes ) fuel cost, etc... is considerably high than a good old gear tractor. Be glad you have it, just learn how to feel your way into gears ( don't grind them until you find them ) :eek: and you will be $$$ ahead :)
