Took our new to us L2950 out today to do some clearing at our land. I had my wife running the tractor while I cut down trees. She ran over a couple of small trees that were a little to big and broke the shear bolt. No biggie, I just did not have another.
However, after finding that and beginning to trouble shoot wy the Brush Hog would not engage, the left rear tire was flat. Turns out that the threaded ring on the valve stem was plastic and it cracked and was leaking at the valve stem. No way to fix other than breaking the tire down and replacing the valve stem. I had a brass semi valve stem at the house, so we loaded up and came home so I could replace it. Used the drive on the tire method to get the bead broke (only broke down the inner bead on the valve stem side of the rim) and replaced the valve stem, however I cannot get the tire back on the bead.
I have tried everything I can think of. We have soaped up the tire/rim and placed it with only the tire being supported and to jump on the rim while pumping in air. That did not work. I tried the starting fluid method, and could not get the Whoomp! ignition, so that did not work. Even tried putting a racket strap around the middle of the tire tread and tightening down to force the bead to the wheel and seal enough to hold air and inflate, and that did not work.
Does anyone have any other suggestions on how to get this bead sealed on this tire? We are trying to clear land to build and we are shut down until we can get this tire back in service.
Thanks
Thanks
