Gearbox, gear leve ?? l..how to OIL ?
jeanot71
France
hello,
sorry I use a translator.
I try desperately how grease or oil my gearbox.
I have a KUBOTA L1500DT
on the box of the gear lever I have 2 purge (in red in the picture)
but where we put the oil?
thank you for your help.
if you help me, I like the pictures or videos because I'm not very good at mechanical or English.
thank you
Stumpy
L175
Dec 1, 2011
848
NE Ohio
The fill cap is marked by the red arrow. It's just behind the shift levers.
On the left side marked by the green arrow is the level plug. Remove that when filling. With the tractor on level ground the transmission is full when fluid just spills out of the level plug hole.
Do you want pictures of the drain plugs too?
jeanot71
France
ok thank you
I was not sure this is the oiling at the same time that oil rewash and rear deck.
thank you again for your confirmation
