Hi folks,
I have a g4200 that I'm having issues with the key switch housing rotating in the hole in the dash when you twist the key to start it. There doesn't appear to be anything to keep it from rotating except tightening the nut on the outside of the dash.
I've seen other switches that have a washer between the switch and the mounting panel that has a tab that locates in another hole, which prevents rotation. I've also seen switches that have a key or notch in the switch that interfaces with the mounting panel and keeps the housing from rotating.
According to the last owner, this is a replacement switch from Kubota, as the mower was his deceased grandfather's and no one in the family knew where the key was located. So it may be the wrong switch.
Any ideas?
Thanks,
Kevin
Any ideas?
Thanks,
Kevin
