G1800 coolant capacity
reclineaholic
L355SS
Sep 8, 2017
Tulsa Ok
Just got a new to me G1800 with 1100 hours, it's in pretty good shape but there are a few things that need attention. The bracketry that holds the steering wheel is broken, the charging system is not working, the glow plugs don't come on, fuel gauge doesn't work, and it was steering to the right ok but barely turned left at all.
I pulled the body off so I could clean everything really well and fix the broken bracketry for the steering wheel. With the body off I fixed the steering issue by moving the output arm on the steering box to a more center spline position. I've checked out the driveshaft, which seems to be in good shape and I cleaned the radiator and flushed the cooling system.
I have a few questions,
-Any suggestions on what else should I look at before reinstalling the body?
-Is there anything common that could cause the 3 electrical problems I'm having?
-So I know how much antifreeze to add, What is the coolant capacity?
Any and all help is much appreciated!
100 td
Aug 29, 2015
1,776
9
38
ɹǝpunuʍop
Check the fuses, probably 3 there somewhere, glowplugs probably go directly thru the IGN switch and it's common for the switch to have high resistance or fail, check eack glow plug. You probably have a dynamo and regulator, it needs power via fuses to work, but the regulator could be cactus. Get a multimeter and start checking. No idea on coolant capacity, buy a 5 quart of premix and fill it up.
