Fusible Link
KennethH
L1802DT
Nov 20, 2016
14
Covington, LA
I have an L1802 similar to L235/L275. I cannot find a part number for a fusible link. Does a anyone know the part number? Thanks
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,252
1,031
Williamstown Ontario Canada
While I too cannot find the fusible link searching on Messicks for the L235/275, the wiring diagram certainly shows one.
I believe they are build to a standard and part number 38430-34530 for $8.07 will work. It is a green one rated at 40 amps.
Later I searched on Kubota.ca and found the proper fusible link which has part number 3843034530 which is the same.
Dave
JohnDB
M4500DT
Jun 9, 2018
420
76
NZ
You likely know this but it is possible to convert to a slow blow fuse.
Dave
I'm interested, how do you convert to a slow blow fuse - what amps and are there any advantages/disadvantages? Thank you.
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,252
1,031
Most automotive places sell the slow blow fuses. That is the benefit in that they are readily available today and modern vehicles are designed using them whereas fusible links are generally sold by dealers to service older equipment.. Otherwise there is little reason to change.
Sometimes the challenge is getting the fuse holder.
Dave
JohnDB
M4500DT
Jun 9, 2018
420
76
NZ
Dave
Thanks, is there any need to change the fuse rating? Or do the new slow-blow fuses blow at basically the same amps and milliseconds as the old fusible link blows?
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,252
1,031
Your green fusible link is rated at 30 amps.
Slow Blow fuses come in many amp ratings so buying the correct 30 amp one is essential to maintain the appropriate level of protection.
Dave
JohnDB
M4500DT
Jun 9, 2018
420
76
NZ
Dave
Thanks Dave!
5,532
Fusible links can be replaced with either fuses or circuit breakers. 'links' have been a great 'scam' to make money for equipment mfrs. Cars ran for DECADES before 'links' were dreamed up, planes fly without links....riders use fuses to protect the stator...
