Bx2370, engine D902.
Has anyone had problems with the cut-off plunger stuck in OFF position inside the fuel pump?
Opened the control part of the pump (rear section) and found out that : when the plunger goes all the way in, it gets stuck and i have to pry it to release to the ON position. My solution was to readjust the screw on top of the pump so the rotary bracket does not push the plunger completely in, but still does the job of cutting off the pump. It works for now, i hope it'll last.
