You can also have a local injector shop clean and reset up your existing injectors, typically they replace the nozzles, reset the pop pressure to specs and test the spray pattern.
That is if you have a local shop - check with a diesel repair shop to find one.
But if new injectors are only $63 each, that is extremely cheap for highly machined diesel parts. Hard to beat that price at a injector shop.
David
