Fuel Gauge
AndyM
BX25DTLB
Sep 21, 2016
514
168
Vancouver Island Canada
I have made a habit of keeping the fuel topped right to the top on the theory it would help keep any condensation from being a problem as I live in an area with very high humidity.
I see my fuel gauge now reads low - plumb full shows 3/4 on the gauge. I have run the tank down to what I THINK is about half and then filled it back up. Still shows 3/4.
Not a huge issue but I have read some folks are having panel problems so I am wondering if it's related.
mickeyd
Mar 21, 2014
1,192
Guin, AL
Probably not.
I know that my gauge shows less in the tank than there really is. When the gauge reads less than a 1/4 tank, it is more like 1/2 full.
I think that Kubota does it to help keep people from running out of fuel.
3,375
That's sorta like my wife telling me we have to be somewhere by 2 o'clock.... when in fact the event doesn't start until 3.... She knows I'll drag my feet...because I know she's fudging on the time so we won't be late.
She sweats it out and gets all stressed-out...while I relax and we get there on-time anyway.
The reason the gauges show less fuel than actual is more likely because corrosion and built-up resistance in electrical connections have added resistance to the indicating circuits thereby rendering the system less-than-accurate. Does that matter? No likely... because you acclimate to the errors and adjust your practices accordingly.
AndyM
BX25DTLB
Sep 21, 2016
514
168
interesting about the change in resistance. For the first year all read well. Then the gauge started to read low, which was why I wondered about the panel. The carport I park in gets pretty muggy in winter so maybe that's the problem.
anthonyv
BX24 BX2200
Jan 24, 2017
122
19
SC
My bet is a rusted out fuel sending unit. Very common problem with these machines. They start rusting, get weird readings on gauge, then crud up the tank & plug up the fuel lines.
AndyM
BX25DTLB
Sep 21, 2016
514
168
Anthony
That should be a warranty item I would think. Do you know how easy it is to change out? Hate to think I am looking forward to plugged filters and lines.
anthonyv
BX24 BX2200
Jan 24, 2017
122
19
SC
Have a BX24 so no warranty. You need to remove ROPS & then unbolt fender. Sending unit is on left just in front of ROPS mount. I have done two so far & keep a replacement in the shop. As to why they rust out I don't think anyone has ever gotten an answer from Kubota.
AndyM
BX25DTLB
Sep 21, 2016
514
168
Thanks for the info - I will have a look at the time and parts to see if it would be better to just do it or get the dealer involved. I doubt they would do a house call and it's a major hassle to get the tractor to them.
