Frontier Broadcast Spreader
LONGBOW42
B2650, loader, mowing, seeding, rake, post hole digger, rear blade
May 19, 2020
25
Chadds Ford, Pa
Hello,
Just got a B2650 with FEL and looking for a spreader for plots. I have an opportunity to purchase an almost new Frontier Broadcast Spreader B1023.Will this work ok with the Kubota? Anything else I need to know?
Thank you!
UpNorthMI
May 12, 2020
849
567
Up North, MI
This spreader is a Cat 1 attachment, just make sure your rear arms open wide enough for you to mount the spreader, they should on your B2650 it is a Cat 1 tractor.
Last thing to consider is the PTO shaft length, it may require shortening depending on the model of tractor the owner used, there are lots of videos online of how to size and shorten a PTO shaft.
I have several PTO spreaders that I use on L3200 and L3901 for both pelletized lime and fertilizer, my only comment is that you wash and rinse the spreader after use.
Good luck with your purchase.
LONGBOW42
May 19, 2020
25
Chadds Ford, Pa
Thank you!
RBA50
B2320, LA304 loader (B1658 QA), B2789 snowblower, RCK54-29B MMM, HF quick hitch
Apr 29, 2013
133
20
Goldendale, WA
Also consider that the PTO shaft may already be too short, depending on what it was mounted to before. Too long is easy to fix, too short is harder.
bambam31
L3800HST 4x4,R1,FEL, 6'disc, 5'bush hog,piranhaTB,6'grader,6'rake, 48"forks
Apr 3, 2014
321
27
23
Mobile, AL
Washing the Spreader is good advice. I always spray my spreader with silicone or WD 40 when it is dry. I always wash the tractor too. Fertilizer will corrode metal in a hurry.
