Front end loader
4,930
Will a front end loader off a BX 2200 fit my BX 2360?
Wbk
307
St Adolphe Manitoba Canada
Hi Skeets the loader on the bx2200 is a la211, the bx2360 is a la243. We have both a bx2230(la211) and a bx2660(la243), the only difference that I can see are the frame mounts, the bolt holes won't line up, if the loader is cheap enough with a little modification I think it would work. I've never tried swapping them out to see if the loader itself is the same but the appearance and measurements seem to be. They're at two different locations now but they should be together next week one day, I can check closer then if your still interested. Hope this helps you Barry
4,930
Thank you my friend, if it might work with out a ton of jury rigging cool if not then I will pass on it,,:D
