I have a F3560 and F3690 both secondhand and new to me recently. I jacked up the rear of the F3560 and oil gushed out from the top axle case. See pic.
I’ve been investigating the rear steer axle seals on my Kubota F3560 and F3690(F3680) as they share pretty much the same parts and have the same issue, worse on the back right. The seal part number 67910-56840 (diagram reference 080). It appears that Kubota installs these seals with the cavity and spring side facing outward (toward air/dirt) rather than the cavity and spring inward toward the oil/lubrication. This can sort of be seen in the service manual. see pic, the springs face the pivot. This goes against the standard oil seal installation practice, which is to have the spring side facing the oil to maintain proper sealing pressure.
The Problem:
Design Flaw?
Has anyone else dealt with this issue? Would reversing the seal orientation improve longevity, or would it cause other unintended issues? Let me know your thoughts! I am about to order new seals and metal bushings and I would hate to do this in 12 months time again.
Also the plastic bushings part number 67910-56430 on top of the rear gear case where the steering linkage pivots was completely worn and in small pieces in the grease. I replaced one of these and it seems to tighten up the steering pivot. I need to replace the rest. How often do these plastic bushings need replacing?
The Problem:
- The top and bottom seals have part 060 in the digram going between them, the part is a metal bushing that allows the shaft to pass through.
- The seal lips and cavity get dirt packed into them, they wear grooves into part 060over time. The spring corridors and fails. See pic.
- Once this happens, oil starts leaking from the top axle case since the seal can no longer maintain a tight seal.
- Replacing all these components adds up in cost, making this a frustrating and potentially avoidable issue?
Design Flaw?
- Arai, the manufacturer of these seals (ARS SDD type), states that the spring side should face the oil/lubricant side to prevent oil leakage. Seal direction diagram
- However, Kubota installs them with the spring outward, which leaves the spring cavity vulnerable to dirt buildup. This leads to seal and spring corrosion, failure, and eventually oil leaks. See pics of dirt in cavity.
- Why did Kubota design it this way? Was this an intentional choice to act as a dust seal, or is this a design flaw that could have been avoided?
- Installing the seals spring-side inward (toward the oil) might improve longevity and prevent premature wear on part 060?
