J Jeff Gordon New member Equipment B7100hst,loaderb1630-c Jul 18, 2015 97 0 0 Oxford,Michigan Jul 23, 2017 #1 What are the problems with moving the rear wheels out to the max position if there is any and is it as straight forward as it seems to do it ?This is on a b 7100,I am also going to fill the tires to 75%with wwf.
Tooljunkie Well-known member Lifetime Member Equipment L1501,home built carry all, mini plow blade. May 13, 2014 4,150 33 48 61 Lac Du Bonnet, Manitoba,Canada Jul 23, 2017 #2 Whether its 1 inch or 3 it will make a difference. Fluid will make the biggest difference.
J Jeff Gordon New member Equipment B7100hst,loaderb1630-c Jul 18, 2015 97 0 0 Oxford,Michigan Jul 23, 2017 #3 Thanks tooljunkie ,can I move them out to the last hole on the axle where the pin goes in?
Tooljunkie Well-known member Lifetime Member Equipment L1501,home built carry all, mini plow blade. May 13, 2014 4,150 33 48 61 Lac Du Bonnet, Manitoba,Canada Jul 23, 2017 #4 I dunno. Manual would tell you. I suspect if there is a provision to move them out that far then so be it.
J Jeff Gordon New member Equipment B7100hst,loaderb1630-c Jul 18, 2015 97 0 0 Oxford,Michigan Jul 23, 2017 #5 Thanks,Frank!
T twomany Active member Equipment B7200 Jul 10, 2017 793 138 43 Vermont Jul 23, 2017 #6 I moved the turf rears in on the B7200 for the summer. all the better for negotiation of tight areas on my hilly lands. Wide track often exacerbates the slope difficulties. In winter, the track will be widened again, to provide clearance for the tire chains.
