Error Code - E appears and frequently blocks movement
G'day FArmer
All types of farm machinery
Sep 27, 2023
No fixed address
I'm working on a Kubota M120.
When driving (only in High range), the LCD screen (on the dash which shows you what gear you've selected), suddenly shows you an E.
You can be driving along in any gear or just shuffling 'to an fro' but when you notice that the tractor isn't responding to your throttle, you know that the tractor has gone into Neutral and the E has appeared. The only way to rectify this is to stop, pull the High/Neutral/Low lever into Neutral, then select High and away you go until the next time. Some days you can drive all day and everything is perfect - another day, you can get dozens of E disruptions.
Curiously, yesterday I was in 4th gear travelling along and the event happened again.
I pressed the Button on the gear lever to select Neutral but as I did, I noticed that the display jumped from E to 4, only when the button was depressed. As soon as you released the button, the E reappeared. It wasn't till I selected Neutral and then Forward (several times), that the E disappeared, 4 became permantent and I continued on my journey.
Has anyone got a solution?
