Hi All,
Recently purchased a B2320 and have been thoroughly enjoying using it.
I was driving my tractor and noticed the fuel level was at empty, so I stopped the tractor and fueled up. I thought it was odd, because it was at quarter fuel not long before, but attributed the apparently inaccurate fuel reading to the steep hill I had been seeding with grass. When I went to start the tractor, it wouldn't do anything. The glow plug light did work, but not the fuel or temperature gauge. I read the battery voltage and it was at 12. I was able to run a hot wire to the solenoid to get it to start so I could finish up the last hour of work I had remaining. After that, it would still not work and the battery was below 11. Any attempts to start the tractor after that needed a booster pack and a 12v jump to the solenoid. The battery is now reading at 6.5v when the tractor is off, and 8.2v when it's on.
Is this an alternator issue? I had assumed not, because the 2 gauges also do not work. A ground issue then?
Any tips on where to start diagnosing would be appreciated. Thanks!
