Electric Grapple
Kennyd4110
Vendor Member
Sep 7, 2013
1,426
758
Westminster, MD
www.boltonhooks.com
There are quite a few video's showing that on YouTube now, I looked at it while attending the NFMS (National Farm Machinery Show) a few weeks ago, I personally think it's overpriced at $2000 for what it is. You can get into small economy grapple for about the same money including the 3rd function hydraulics.
dochsml
L4701HST
Jan 21, 2020
216
20
Leonard, TX, USA
Yeah, I didn't catch the price. They would need to get better than that. Especially since it's a one trick pony and third function can be used on other implements.
heinsite
Kubota L3400, front loader, b75 Backhoe, Bush Hog, box blade, rake
I think over priced also. Has 1000lb pressure which a good bit lower than hydraulic I think. I think it's a great alternative, but maybe $1400? They should have a bolt on version.
Sent from my SM-G975U1 using Tapatalk
SidecarFlip
Banned
562
+3 on that. I think they are a bit over priced as well but a good alternative to investing in a 3rd function setup and clamping force is a bit on the puny side but then linear actuators don't develop a lot of clamping power anyway.
Would be fine for general cleanup but not good fir say a tree trunk.
BX23-S,57 A-C D-14,
5,926
While I can get a 2000# LinAct for $300 Canucks, it's slow, like most. so 1/3rd the $2K may be JUST the LinAct. Thing draw 25Amps ,so a real good battery and alternator is a MUST.
dochsml
L4701HST
Jan 21, 2020
216
20
Leonard, TX, USA
I don't know what they put in the Bx for a battery or alternator, but there isn't much in my L (45 amps I think). So, yeah, they don't seem to do these tractors up like trucks where you can add all sorts of electric doo dads.
SidecarFlip
Banned
562
Yep 45 amp. The M series cab's are 60. That isn't an excessive amount of capacity by a long shot.
Bmyers
May 27, 2019
3,520
4,537
Southern Illinois
If I'm reading the info correctly, my Grand L3560 has 60 Amp system.
Tim Horton
291
67
Lake Superior
I think it is a really good idea...
Not that expensive compared to many options. More than powerful enough for most small tractor sizes and applications..
If you have a bigger need, or bigger equipment, this is not for you.. That simple.
What I would look closer into is if, when they make a version that will bolt onto a set of pallet forks... That would be cheaper, better use of an on hand attachment..
My 5 cents of opinion..
fruitcakesa
M 6040
Oct 26, 2010
856
270
Cavendish Vermont
This is the route I went with the Green Thumb.
I already had the hydraulics to run it, but even if one had to add 3rd function or a remote, it would be a cheaper, stronger option.
SidecarFlip
Banned
562
Green Thumb? Have a link to share?
mdhughes
L3901DT
Dec 10, 2014
1,399
1,277
Ste Geneveive county, MO
I was a little surprised at this line in the description:
Engineered for Sub-Compact tractors up to 32-hp with a front end loader.
SidecarFlip
Banned
562
He means "Green's Machine", the "Thumb".
http://www.greens-machine.com/
Just ordered 2 actually. One for the spare bucket I have and another to mount on my skid forks which I tend to use more for moving branches and stuff around. Nice and very reasonable price wise. I got long ones for the bucket so I can tote round bales too, though I mostly spear them from the ends to load them.
Shipping isn't unreasonable either.
vic gerbasi
M110 L3300
Feb 19, 2016
232
dugald mb canada
i requested info on this product recently : asking about a clamp on system onto a bucket cause R&R of pin on bucket is a real pain... still waiting for response
3,716
Danannah@gmail has a solution for your pin on bucket issues.
This video is not Dan, but Dan made a set of these for me and SOLVED my pin-on issues of switching implements.
https://www.youtube.com/watch?v=KuktqggNDCw
