Discontinued L185, L245 steering arm tie rod found
Oil pan 4
L185 turbo
Sep 21, 2017
418
118
NM
The manual shows the both steering rod tie rods on the L185DT as being the same. But if your tractor has ever had the steering box replaced it has a small tie rod on the pitman arm end that was discontinued by kubota a long time ago.
I'm assuming the replacement steering boxes are all L245 with a small tie rod.
Either way if this is an L245 part and my LKS (local kubota shop) couldn't find it, if you did get a genuine kubota part it's going to be around a $70. But, you can get a moog that's pretty close for around $20, might have to shorten it a little.
The part number is: ES421R
Your are on your own for the other end of the steering rod that connects to the spindle. Some one welded a big 3/4-16 left hand thread nut on the steering rod and put a big old imperial threaded tie rod on there. But if you are out of ideas and are willing to mod your tractor a little. The moog EA150L might be an option. You will need a full size 3/4-16 french nut to weld on and a thinner 3/4-16 french jam nut to make it stay where you set it.
