Diesel in engine oil
Fastwestie
Bergerac, France
Hi
My first post!
I have an L345DT with the V1501-D engine and have what seems to be diesel in the engine oil. The tractor has stood for a long time and only started occasionally. When it was started it spat oil out of the breather so we checked and found the sump full roght up.
We suspect a seal in the pump, but that looks like a difficult job. Anyone have any advice please...
Regards
fj40dave
Sep 24, 2009
425
257
Yelm, WA
Welcome aboard!
I had a similar problem with a full crank case spitting oil out the breather and dip stick port's.
Turned out to be a bad seal on the hydraulic pump!
If your CERTAIN it's diesel fuel in the oil, you have a bad fuel injector (stuck open)....is the tractor running rough?
Check out my picture link in my signature - it's sorta a detailed view of the rebuild I did for just a bad seal in the hydraulic pump. :)
Fastwestie
Bergerac, France
Welcome aboard!
I only got it running properly today and am going to keep an eye on all levels. It did smell like diesel, but I hope it is hydraulic oil...
tk1469
147
North Central Michigan
Dear Eddie - I can't speak about your diesel in the oil problem - but I do agree that these guys on the OTT are The Best. I've learned a ton about Kubotas and tractors in general since I started visiting OTT on a regular basis. My hat is off to everyone who contributes to this treasure of information.
fj40dave
Sep 24, 2009
425
257
Yelm, WA
I couldn't agree more! There's a wealth of knowlege here.
SDV (Service Department Vic) once posted that I had an answer that was right on the mark.....I felt like I just got promoted to chief parts washer from floor sweeper! :D
Stick around and you're going to have something to add that benefits someone!;)
exkx61
25
Bigfork,Montana
I had same problem and it was "O" rings on injector pump.Rubber gets hard and does not seal.Diesel can leak in either direction to inside or outside or both. About a 3hour job on my Kx61 removed intake manifold to access rear screws on injector pump. Three "O" ring on each unit. Not a hard job.
Fastwestie
Bergerac, France
Thanks for the info, sounds like that might be my problem.
Does anyone have instructions on how to remove and strip down the pump? It seems like I have to get to the timing gear through the front of the engine.
BTW, how do you find the KX61? I have a KX41-3 as well as the L345DT tractor :)
exkx61
25
Bigfork,Montana
The info I have is the pump should be good for life of engine and is better left alone as the shims under pump determine timing. KX 61 seems to be a very good machine - need more seat time .
Fastwestie
Bergerac, France
Well, I checked everything over and still couldn't find the fault. I took the injectors and pump to a diesel specialist and the outcome was a bill for 1000€! :eek: It needed the injectors rebuilding and new pistons and valves in the pump.
