Did it again, broken fuel filter housing.
Benhameen
Jan 27, 2013
713
136
Southern IL.
Well, I was out clearing some brush yesterday and something clipped the fuel filter housing and it broke. This happened the first time a few months after owning my L3800, about ten years ago.
Of course this happened about as far away from the barn as I could get on my property. I had a pair of vise grips in my tractor tool box, so I pinched the fuel line to prevent all the fuel from leaking out. An hour later I get back with a T to bypass the filter housing in order to get it back to the barn and out of the woods. FYI, you don’t need a T, just a fitting to connect the fuel line. The top hose is just a vent, wish I would have realized that at the time. Got in hurry as it was going to get dark soon. Lesson learned…
Once the fuel line was reconnected I tried starting the tractor and she wouldn’t fire. Turns out the vise grips didn’t pinch off the line enough and the remaining fuel about 1/4 tank had leaked out. Now the fuel system had air in it. Back to the barn, then to buy fuel. 45 minutes later it’s dark and I’m back with fuel and wrenches to break loose the fuel lines.Still couldn’t get fuel through the lines. Found a thread here about an L3200 that wouldn’t start and it was mentioned that there is an air vent cock. Well that did the trick, started getting fuel through the lines, buttoned it all back up and she fired up.
Lesson for the day, check the manual before guessing and wasting time, lesson learned…
Has anyone fabricated a guard for the exposed fuel filters on the L3200/3800?
johnjk
Apr 13, 2017
1,809
2,200
West Mansfield, OH
Check out Paul and Kathy Short and their company Specialty Repairs out of Canada. I have one of their fuel filter guards on my B3200. Great products and service
JasonW
873
584
Al
The first year I had my L3800 I replaced the factory one with a Racor unit. Up out of the way above the loader frame mount. Never liked how they hang down like that.
5,188
Their website:
specialtyrepairscustommods.com
They are in Bay Roberts, NL.
Nice folks!
11,757
I made one for the BX after adding a fuel filter to replace the one under the tractor. Making guards is very easy if you have material and the right tools. It's also very satisfying to make something that is better than anything you can buy, and a lot cheaper too.
JasonW
873
584
Al
Honestly it’s been so long since I did it I cannot remember an air return line. I added a small ball valve on the supply and used barbed fittings same size as factory on the filter housing. The Racor has a vent plug also. No issues with almost 500 hours.
