Deck lopped sided
Steve Sr.
BX 2200
May 31, 2018
Carl Junction , Mo
Hi all , I have a 2003 BX 2200 60" mower . Tires are inflated the same . The deck is lower on the left side . Is there an adjustment for this . And I also can not turn my height adjustment to "TOP" . Any help would be appreciated . Thanks Steve Sr .
anthonyv
BX24 BX2200
Jan 24, 2017
122
19
SC
At the rear deck lift link there is a threaded rod on each side hanging down next to the pull out pins. Remove link & turn to level deck. At the right rear of tractor next to right rear tire there is an adjustment rod, usually with two nuts locked together. Loosen nuts & turn inside nut a little bit in or out to adjust deck riser & allow knob to go to top, then lock nuts back together.
Steve Sr.
BX 2200
May 31, 2018
Carl Junction , Mo
Thanks for the info . I will start checking tomorrow , I just put mower away . It looks like both sides are at the same place threads wise . So my thinking is the side that is higher would probably need to come down by lengthening the rod . ??
Steve Sr.
anthonyv
BX24 BX2200
Jan 24, 2017
122
19
SC
Hard to say without seeing the linkage, but it is fairly straight forward. Just make sure the links or hangers are not bent or broken, has been known to happen. If you say the threads are equal I would look for bent or broken link. This would also affect your height knob as well. Hope this helps.
Steve Sr.
BX 2200
May 31, 2018
Carl Junction , Mo
Thanks a bunch . Due to some physical limitations (probably mental limitations too) , I called my dealer and they are sending someone out .
