Hi,
Currently in the process of rebuilding a Kubota D902 engine...
I have the shop manual for it, and I'm following the diagram for the timing gears.
I've set TDC on the flywheel side, and lined up the dots on the timing gears.
It's a little confusing though because of the gears having helical teeth.
The diagram in the book shows the dots lining up all perfectly.
In my 3D reality, it doesn't quite look the same.
I think I've lined them up correctly,
but was hoping to get confirmation from a Kubota engine guru.
Thanks in advance!
Jonathan
Thanks in advance!
Jonathan
