D850 engine on ebay, says from 7100, I dont think so!
Rob
B6000DT / B7100DP /B8200DT/L225/Globe PTO Chipper/Lewis Backhoe/huxley TR66
Nov 22, 2009
679
11
Leafy England....
hi guys, saw this item on ebay tonight,
link: http://www.ebay.co.uk/itm/Kubota-D8...arden_GardenPowerTools_CA&hash=item4aba6c2e81
anyway, he says its a D850 taken from a 7100, an D850 yes, from a 7100, i cant see it to be honest.
for one thing has no hydraulic gear pump on the engine, there is a hyd pump which is mounted on the lower left hand side of the engine block just above the oil filter, the engine cover will never go on with the pumpsti cking out there, and the 7100 doesnt have power steering either, no onboard fuel pump and what looks like used to be a fixed throttle setup too.
both radiator ports are wrong also, and the fuel return pipe is back to front.
Maybe from another kubota 7100? but not a b7100.
good basis of a project if you need some parts maybe.
rob
