D722 Engine identification important? pics
bcomstock15
GF1800 4wd
Nov 12, 2011
22
Calgary, Canada
I'm looking to replace the engine in my GF1800 (small outfront mower) it uses a D722 engine. I found a used engine that i would like to put in it, but it was obviously used for something else other than a tractor before. I've heard that not all engines of the same model are alike, and that it's very important to make sure they have the same OEM spec's.. this is a good deal on the engine, so i'm wondering what types of problems i might find, if any? is this as important as they say? the ad specifies that it has been "completely re-built" just wondering what i should be weary of, it's a long drive to pick it up.
attached pics of engine, what problems, if any, can you identify? i see a melted oil cap, do you think it was in a fire or something?
Thank You for your help.
birddogger
433
Pittsburgh
Looking for an opinion? Yeah it has seen a fire. No, it doesn't look rebuilt, at least not in a recent life. It has seen too much weather to consider much more than a complete core. It will need a change of flywheel. At least it has a new starter. They put a rag to keep rain out of the intake but not the exhaust ports; you can imagine what a little rain down an open valve might do to a cylinder.
bcomstock15
GF1800 4wd
Nov 12, 2011
22
Calgary, Canada
Thanks for your help
What do you mean by 'its seen too much weather to consider much more than a complete core'? i don't know much about engines.
Do you think what i heard that not all engines of the same model are alike, and that it's very important to make sure they have the same OEM spec's is true/important. He wants $1000 for this engine. I have a current one with 200 hrs and a broken head (so i could take parts from it for this one). What would you do? ive been looking for a decent deal on one within driving distance for a while...
bcomstock15
GF1800 4wd
Nov 12, 2011
22
Calgary, Canada
Heres what the seller has to say about the engine:
The motor was used in a Timberjack skidder to run a hydraulic pump that ran a 60 foot altec lift. It is used by Asplundh tree company to trim trees. I am the foreman on the machine. The motor was getting tired ie: losing power and smoking. Asplundh decide to replace both motors on the machine with new motors. They gave my the old motor and I gave it to a cousin to use in a project he has where he needed to run a hyd. pump. He had the motor rebuilt at almost $2000. He caught the machine on fire and some of the Kubota engine got burned. I took the motor back to the shop that rebuilt it and had them pull the head and check out the motor. After replacing a couple hoses that got melted they put the motor on a stand and fired it up. It runs great and other then a melted cap it looks good. The rest of the project did not survive so good so we want scrap the project and sell what we can.
kuboman
721
You say your engine has a broken head. Meaning what? For less money you can replace the head on yours and not have to modify anything.:confused:
birddogger
433
Pittsburgh
Well looking at the whole situation. You could add up the $400 for the new head and the $500 worth of new starter on that engine and you are almost at the asking price of $1000. Besides changing over the flywheel from your old unit and maybe a new valve cover gasket (cooked in the fire). That engine could be worth a go.
I'd get in and minimally connected; start it up and not rev above idle and watch for smoke,or leaks and listen for clanking or rattling. Let it idle for a while before putting it under load and putting around a bit to assess its' power, servicablility.
