D600 governor?
Webn237
73
Southrn WI (Monroe)
Whats the safest rpm to run a kubota d600 without doing damage? We are running it and sounds like its around maybe 2000-2500 rpm. The max rpm i read is 3600 rpm
Sent from my SM-G935R4 using Tapatalk
BruceP
G5200H
Aug 7, 2016
852
370
Richmond, Vermont, USA
I understand the D600 is DESIGNED for 3600 RPM. This should be where the best fuel-consumption/power ratio is.
The D600 was a favorite for electric-generators which MUST maintain EXACTLY 3600 RPM. (3600 divides down to generate the 60hertz frequency)
Lets not forget that 1000s of D600s were used in refrigeration units (on tractor-trailers) These things ran for months at a a time.
Personally, I like the D600 engine in my G5200 garden-tractor. The Hydrostatic xMission does not like when the engine is below 3600. When the engine is below the specified RPM, it forces the HST to work harder than it should. The manufacturer of the HST in my G5200 (Eaton) specifies 3600 as the proper input RPM for best power-transfer to the wheels.
